Kelco
Established Member
My 360 died a few months back with the RROD. MS repaired it and replaced mobo and DVD drive. Two after coming back it died again. MS again took it back for repair and replaced the motherboard. Now when it's turned on there is a very loud 'fan noise' which lasts for 3 to 4 minutes before getting quieter and going back to the normal 360 sound (never dead quiet but thats the 360 for you!). I called MS and after 30mis on the phone they took it back again to fix. I wrote down on the repair sheet inside the box exactly what the problem was. The 360 then spent a week in germany, I'm in the UK, and come back with the same problem. All they did was change the DVD drive! Has anyone else had this before? Is it possible it will get better over time? Or worse? I'm a little fed with MS and waitng around for couriers...
thanks
thanks
