360 HD image discrepencies
Discussion in 'Xbox Forums' started by kukri, Mar 20, 2006.
  1. kukri
    kukri
    Mar 14, 2006
    Hello,
    I'm running my 360 on a 26" Samsung HD set via component and there appears to be a problem with the image. Whenever there is a lot going on on screen a horizontal line shoots from the bottom of the screen to the middle, blurring and disrupting the image briefly. I don't believe it is a disc problem as it occurs randomly. It makes FPSs impossible due to the amount of movement involved and is highly off putting in DOA 4, ruining my otherwise godly countering skills . Is there something wrong with my set or system?
    Thank you.
  2. matt_p
    matt_p
    Apr 7, 2005
    851
    28
    Nottingham
    +38
    That's the 'tearing' problem that's associated with the Samsung sets. Run a search on the LCD forum for "samsung" and "tearing" and you'll find enough information to keep you occupied for a year.
    Call Samsung tech support, they'll send you a disk and cable to update your telly's firmware. That should fix it.
  3. kukri
    kukri
    Mar 14, 2006
    Thank you very much sir!
