360 HARDWIRED but still getting moderate NAT?!
Discussion in 'Xbox Forums' started by supergeek, Jan 11, 2008.
  1. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
    any idea why this is happening i cant seem to figure it out or find the answer anywhere:confused:
  2. m1ket
    m1ket
    Aug 24, 2005
    3,694
    UK
    +332
  3. cyman
    cyman
    Sep 20, 2005
    326
    28
    +43
    you can either forward the ports as listed above or you can set your router up with a dmz which opens all ports to the xbox which is fairly simple to do just give the the same ip adress as the one you put into your xbox for eg dmz 192.168.1.10 xbox ip address set manualy in the network setting to the same 192.168.1.10 works every time. (nearly)
    hope that helps
  4. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
    hi thanks for your responses
    Sorry if i didnt make this clear but my 360 is hardwired into the wall socket, i don't have a router of any kind, so im bemused as to why it said moderate, tried it earlier but now it says strict :rolleyes:
  5. Desmo
    Desmo
    Jan 4, 2001
    14,560
    Braintree, Essex.
    +6,663
    What do you mean by hard wired into the wall socket? And how are you connected to the net? ADSL or Cable? There must be some kind of modem or router involved somewhere along the line.
  6. Ali1978
    Ali1978
    Feb 28, 2007
    82
    London
    +6
    i was tired of forwarding ports on my old dsl router (cisco 837), i picked up a new netgear 834GT and I havent looked back:thumbsup:
    As long as you have upnp enabled you shouldnt need to forward any ports.
    I have played many 360 games now, all with working voice chat and not forwarded a single port:clap:
    good stuff:smashin:
