360 GPU Overheating
Discussion in 'Xbox Forums' started by UKDStrawdog, Mar 10, 2006.
  1. UKDStrawdog
    UKDStrawdog
    Dec 6, 2005
    1,491
    Burnley
    +113
  2. Steve-L
    Steve-L
    Nov 12, 2005
    3,383
    Liverpool
    +149
    :oops: Those must have been made on a Friday afternoon :D
  3. ukkev2000
    ukkev2000
    Apr 12, 2004
    1,027
    48
    Hampshire
    +51
    Well done German fellows! :clap: :clap:
    I thought that heatsink looked wrong as soon as I saw it. Waht's the current failure rate in the poll? 20%?
    A fifth of the production had someone not taking the foil off - must have been a few lines in the factory who weren't taught how to do this job. Well, if you will get these things made in the cheapest place...:suicide:
  4. Andy3
    Andy3
    Jun 20, 2005
    634
    Cheshire
    +19
    On the other hand, the foil could be intentional:
    http://www.aavidthermalloy.com/products/options/tapes.shtml
    When I was in the tV trade, many manufacturers changed from using the old mica-washer-with-compound to dry silicone rubber washers. We looked at these things and swore they couldn't possibly conduct heat, but they worked fine!
  5. Kainz
    Kainz
    Dec 17, 2005
    149
    19
    In a cowfield, London Uk
    I think it's normal. They're basically using TIM pads that have a foil carrier on them.
  6. StephanK
    StephanK
    It's normal, MS confirmed meanwhile that the pad they're using has an aluminum carrier - and linked to the product specs of said pad at the manufacturers homepage. Guess those folks at that german modding store didn't know about foil backed thermal pads and got all excited. Well, they sure had their 15 minutes of fame.
    Here is an official MS statement in english:
    http://www.kotaku.com/gaming/microsoft/msoft-responds-to-xbox-360-foil-video-159734.php
    What german product manager XBOX division - Boris Schneider Johne thinks about this scare can be read (if your german is sufficient) in his private blog here: http://www.dreisechzig.net. In short, he is not amused.
    My opinion from skimming thru various posts made by one of gs24 folks on a few german modding sites (namely nexgame.de and modcontrol.com), the guys 360 croaked after he modded it and MS refused to replace it since the warranty seal was broken. Guy got cheesed off and completely took the thing apart trying to fix it himself and stumbled over the foil. He was claiming that MS forgot to remove the "protective film on the thermal pad" - apparently lacking knowledge of or disregarding the existance of foil backed thermal pads. Saw his chance to boost popularity of his modding store by spamming the net with his findings that he published conveniently right at his online shop page selling a 360 modding kit.. I would say his ad campaign kinda backfired.
  7. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,717
    +874
    Well I have no idea how it can possibley be effective having that much thermal compound and a piece of foil?? :confused: It's only supposed to fill the microscopic holes?
