jim_is_ere
Having just purchased a panasonic 32 inch HD ready TV in preperation for the 360's launch I was wondering if anyone knew what connectivity would get the best out of the Xbox 360.
I think the options are component and vga leads on launch. I have had a look at the TV specs and the PC signal is high density d-sub 15pin, it does mention that the PC signal is magnified or compressed for display so it may not be possible to show fine detail with suffient clarity!
So I am guessing the way to go for the 360 with a high def TV is component leads for true HD action
Can anyone clarify this for me?
cheers
Jim
cheers
Jim
