360 connecting to live via PC
pilgrimchris
I'm trying to help a mate who is trying to set up a 360 as follows...
360 wired connection into back of pc, then thru the pc onto the internet
He's been told by BT that this isn't possible and he needs a router but to my mind this should work - I've regularly connected laptops into the back of my pc and got online (although not for some years since I installed a wireless modem/router)
any advice anyon?
kickinoffapong
Having spent countless hours arsing around with this sort of thing, I'm afraid the best advice I can offer your mate is to get a router. Would be 30 quid well spent.
DirectiveFour
I used to connect PC's to a PC to get online, a router is just that really, just make sure internet connection sharing is all sorted and the firewall isnt stopping anything.
DarkEntity
To do what you want you need to have 2 NICS in the PC and enable ICS.
Internet Access > PC Nic1 > PC Nic2 > Hub > Xbox
Hub just gives space for more items on the network.
Or
Internet Access > PC Nic1 > PC Nic2 > Xbox
Indiana Jones
I had no trouble with this type of setup personally.
I am with BT and was using a USB modem so I just connected the 360 to my PC with a crossover cable then enabled ICS and I was on Live within a few minutes.
Now that I use Wireless though it is even easier because my Router is always connected to the net so whenever I turn on my 360 it connects to Live within seconds.
MadamePresident
i have a voyager 100 usb modem on BT and i am really struggling to get it to find the IP address - what details should be entered into the xbox 360/pc ?
ta
ShadowmanUK
ta
They are on my website as mentioned above.
MadamePresident
ShadowmanUK said:
Gotta be doing something not quite right then, as those instructions work 100 percentile.
do i need to PPPoE settings too with BT ? i dont when i access the internet on the pc
anyway - uploaded my ipconfig , its slightly different to yours in layout but see if you can see anything odd
wormvortex
i connected my 360 to my pc and my pc to my router and it worked fine all i did was bridge the connection between both the lan ports.
Though the leaving the pc got to me so i bought a 10M lead and lifted up the floor board and hard wired it into the router. Who needs wireless:devil:
MadamePresident
ShadowmanUK said:
What about the Dial-up one?
I'm not gonna be around for a few days now... keep trying ;)
yeah i got the network connections and dial up icons
the computer registers the xbox as connected when i power it up (the network icon tells me via a silly popup thingy)
it just fails misserably with the dns settings
MadamePresident
right finally found a solution to the problem
P.C. settings...
IP 192.168.0.1
subnet mask 255.255.255.0
gateway [left blank]
prefered dns 192.168.0.1
xbox 360
IP 192.168.0.2
subnet 255.255.255.0
gateway 192.168.0.1
primary dns 192.168.0.1
secondary dns 192.168.0.1
hope this helps someone in the future with a usb voyager 100 on BT broadband connection
oh yeah my live tag is "divykecks" feel free to add me and kick my arse on gotham racing :)
ShadowmanUK
P.C. settings...
IP 192.168.0.1
xbox 360
IP 192.168.0.2
gateway 192.168.0.1
Those are all on my website, they are the ones I told you to use :confused:
MadamePresident
it was the pc prefered dns pc settings that are left blank on your site that caused it not to work
but i must admit , i would have never got it going if it wasnt for your site - so thank you :thumbsup:
