360 cables?
Discussion in 'Xbox Forums' started by EazyE, Jan 24, 2008.
  1. EazyE
    EazyE
    Oct 29, 2006
    268
    +8
    Hi.
    I currently have my 360 connected via component, the picture plugs are in my HDTV but i managed 2 stretch the cable enough to be able to plug in the audio plugs into my stereo hifi (red/white).
    But i think i might use a HDMI cable for my 360. Only problem is i dont know how to connect it up so that sound will come out the hifi. Its an oldish hifi which only supports the red/white stereo plugs. Is it possible to have picture via HDMI but sound via red/white plugs?
  2. JackFord
    JackFord
    Jan 8, 2007
    689
    +44
    Not the best picture in the world, but you use one of these:
    [​IMG]
    Plug it where your Compo is now, and the HDMI goes in the HDMI slot (obviously).
  3. EazyE
    EazyE
    Oct 29, 2006
    268
    +8
    Thanks. How much are those and where from?
  4. v CJ v
    v CJ v
    Dec 7, 2007
    3,308
    +432
    Alternatively, if your TV has an audio output, plug that into your hifi.
    E.g.
    My xbox / PC / Wii / Digi Box plug into my TV via HDMI / Scart etc.
    I have an audio OUT on the tv (red / white)
    These then plug into the audio IN on the hifi (surround kit)
    This means, ANY sound going into the tv will also go through the hifi / surround kit (when switched on)
    Hope that makes sence :rolleyes:
  5. JackFord
    JackFord
    Jan 8, 2007
    689
    +44
    I got my Audio Block with my Elite, I don't know here else to get them, try Amazon, eBay etc?
  6. fatfingers73
    fatfingers73
    Sep 23, 2005
    1,756
    North Weald
    +155
    I think Microsoft will send you one for free if you contact them, there's a thread somewhere on here.
  7. Bean84
    Bean84
    Nov 9, 2007
    123
    +11
    This is what I did with mine - worked perfectly.
  8. smallclanger
    smallclanger
    May 9, 2007
    2,246
    Southampton
    +463
    I've considered that myself, but if I want to turn the TV off and leave the 360 playing music it wont work..!
  9. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    If its in stand by will it not work as a relay ?, various tvs / videos / amps do this. Various hdmi amps will also do this for you regarding picture also ;)
  10. smallclanger
    smallclanger
    May 9, 2007
    2,246
    Southampton
    +463
    Damn it! I will have to try it now.
  11. EazyE
    EazyE
    Oct 29, 2006
    268
    +8
    Would it not work if i plugged in the component but left the video plugs hanging out and only plug in the audio plugs? And then plugged HDMI in?
    Also how do i get a free one of those in the pic?
    Im doing this because i just tried my Ps3 HDMI lead on 360 and its much clearer on my TV and the colours are how they should be (on component they are weird in some games)
  12. EazyE
    EazyE
    Oct 29, 2006
    268
    +8
    How do i get a free block?
  13. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    I think its this....
  14. EazyE
    EazyE
    Oct 29, 2006
    268
    +8
    Anyone know the email address to contact them?
  15. EazyE
    EazyE
    Oct 29, 2006
    268
    +8
    Cant i just buy a block somewhere?
  16. CDR
    CDR
    Feb 18, 2006
    1,484
    +312
    i've not bothered to read the thread i'm linking to all the way through.. but it appears this is what you wanted?? A quick search of "HDMI Audio Address" brought it up..
    Easy to search, and took me <1min - you've been waiting for a couple of hours for someone to reply.. :p
    (And no, i'm not 'bashing' you.. I used to do the same) :suicide:
  17. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    You right about the search feature its under used ;)
