360 as an extender-transcode360?
Discussion in 'Home Entertainment Computers' started by BSNismo, Jun 1, 2008.
  1. BSNismo
    BSNismo
    Jan 20, 2007
    10,922
    Waterlooville
    +1,367
    Hi guys,
    Im just trying to use my 360 as an extender to my HTPC.In the past with XP ive always used Transcode360 but im having problems with it on vista i can not get it to work whatsoever?
    Are there any known problems with this and vista?
    Also ive got my movies installed on the HTPC and therefore media centre installedf onthe 360,is there not a way of just playing the files without transcode?
    When i highlight the thumbnail and go to play the file it says i dont have the right codes but i do :confused:So then i tryed watch stream and it says transcode 360 is not working?
    Are there any other programs that can do the same sort of thing? i know theres Tversity but i dont really like that.
    The only files i am using are 720p MKV files?
    Thanks in advance :thumbsup:
    Mods sorry if this is in the wrong section.
