K
karl
I had decided to purchase a Toshiba 36ZT29 at £1650 including delivery. I went to the Robert Whyte website and saw that they have the Panasonic 37" plasma (TH37PW4B - silver) for £2349. After a bit of shopping around I can get it for £2400 including delivery.
Well I am now tempted to go for the plasma. It must be placed in a corner so wall mounting is not really an option
Any views about the relative merits of picture quality. I will have a PAL / NTSC progressive DVD player (Philips Q50 from Hong Kong) to supply the set. I believe that the TV will accept NTSC progressive and that the plasma will accept both PAL / NTSC progressive. How do the plasmas perform with progressive scan and in particular PAL progressive ?
I have a separate surround amp & speakers. I don`t need digital TV. I know I could go for the 36ZD26 (nicam) but my wife likes the silver ZT29 and not the blue.
What is the actual screen dimensions of the 36" toshiba & the panasonic 37". I believe the actual difference is greater than an inch ?
I also hear that the Toshiba 42pw16 is available for 2999 incl vat.
I will have a panasonic AE100 projector - hence the PAL progressive DVD player. It is tempting to use that on the plasma.
I could afford to go for the plasma (just) once the associated costs are considered - i.e plasma stand / AV unit if it is worth the extra.
Please, help me choose.
Thanks.
Thanks.
