32ZP48 Problem
Discussion in 'General TV Discussions Forum' started by gmjones, Jul 11, 2005.
  1. gmjones
    gmjones
    Just had my second 32ZP48 as the first had real bad geometry problems. Problem is I have a think black line right across the middle of the TV which flickers! Then after 10 minutes it goes! Any ideas what this is also these seems to have geometry problems as well! Is this a know problem with the ZP48! Should I send it back again!
    Regards
    Gareth
  2. nig28
    nig28
    Most TV's have faults if you look close enough!
    But if you have a black line across the middle, find the cause and get it sorted or replaced.
    Nigel
  3. Skiddins
    Skiddins
    Feb 4, 2002
    102
    16
    Windsor, Berkshire, UK
    Slightly off topic, but does the TV switch automatically between 4:3 and 16:9 depending on input?
    Skiddins
  4. boomshanks
    boomshanks
    Nov 16, 2004
    47
    York
    I have been looking around the forums for a solution to this problem because my tosh 32zp48 has recently started showing an intermittent black line flashing horizontally accross the centre of the screen. I have tried turnng the contrast down, which helped to an extent, but it is still there. The annoying thing is that it won't do it for a few hours, then start up for 10 minutes just to frustrate me.
    Did you eventually find a cure to the problem without sending the set back? I have had my set 14 months now, so tosh warranty is finished I think.
    On the plus side, the set (when it is not flashing lines at me) is outstanding! Component video and prog scan DVD - amazingly crisp picture and vibrant colours.
    Ta
