32ZP48 Picture Fault
Discussion in 'TVs' started by M271, Jun 11, 2005.
  1. M271
    M271
    Jun 8, 2005
    186
    After debating over and rejecting LCD and DPL TVs due to cost and picture movement quality (mostly to watch sky channel and a lot of football), I decided to go for a Tosh 36ZP48, however when I viewed a 32'' model in Currys the other day the picture had a vertical band running down the centre of the screen (I can't remember if it was darker or lighter than the rest of the picture).
    Is this a common fault ? what might be causing it ?
  2. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Hi, I have the 32ZP48. I have never observed any picture faults on this model. I thoroughly recommend it. Regards, yt.
  3. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    It may have been too close to another TV-you can get this with computer monitors too ;) This would cause a dark scrolling band.........
  4. Shwing
    Shwing
    Feb 1, 2005
    127
    +8
    I have the Toshiba 32Z47, and it too has a faint 'light' vertical line down the centre of the screen. This seems to be a common 'feature' of a lot of Toshiba sets, as quite a few people on the forum (with various models) have also mentioned this line.
    To be honest it doesn't really distract me from what's on screen.
    Mark
  5. 9761
    9761
    May 16, 2005
    499
    on my 32ZP48p I havnt noticed anything that you describe
