32ZP48 and connections/cables
Discussion in 'General TV Discussions Forum' started by gmjones, Sep 15, 2005.
  1. gmjones
    gmjones
    I am pretty much new to TVs and connections and I need a little help getting the best out of my TV. I have a 32ZP48 and at the moment I have a VCR/Sky and DVD all connected via Scart. Everyone here mentions that you should connect the DVD to component/coaxial??? What does this mean?
    My DVD player has all the following connections
    Connections: RGB Scart; S-video output; composite video output; optical and electrical audio output; audio analogue output
    What/Where should I buy to connect my DVD to my TV.
    Thanks in advance
    Gareth
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    With your dvd the best connection you can use is a scart cable. If you have the sound ruinning to an amp and not the TV then you could get a RGB only cable(no sound) and connect the sound up from the dvd to amp with a coaxial (electrical) digital cable.
  3. davee b
    davee b
    Jul 19, 2001
    288
    leeds
    +11
    You need a dvd player that can output component to the tv's component input for the best possible picture. Otherwise as has been said RGB scart and coax to an amp is your best option. :)
