32ZD26 Problem
Discussion in 'General TV Discussions Forum' started by necroscope, Feb 14, 2003.
  1. necroscope
    necroscope
    ok have the tv set and thought i would watch a dvd but i know i have done something wrong just cant think of it when i put it onto EXT4 all i get is the sound from the dvd and no picture using componet cables dvd player sd520 ... i know its something simple but i just cant think what it is
  2. bibooo
    bibooo
    Aug 15, 2002
    227
    Earth
    +11
    Make sure the DVD player is set to output either Video or S-Video (doesn't matter which) and NOT RGB. This should solve the problem, you may have to connect it via a scart lead to see the set up menu whilst you change the output.
  3. necroscope
    necroscope
    Thanks thats whats wrong ... had it on RGB on the last tv :rolleyes:
