32wlt66 component query
Discussion in 'LCD & LED LCD TVs Forum' started by scoobysnack, Sep 14, 2007.
Tags:
  1. scoobysnack
    scoobysnack
    Feb 12, 2002
    24
    Lymington,Hampshire
    Have just got round to connecting my dvd player to my Tosh 32wlt66 tv via component (scart before) and cannot get a picture. When i select input 3 it comes up 3c(where it was 3 before) but just a blank screen. What am i doing wrong? If i bring up the setup menu it doesn't even list input 3 under av connection(s).
    Hoping someone can help and i'm not being too dumb!
    scoobysnacks
  2. mpn
    mpn
    Apr 22, 2006
    8,062
    Stockton
    +575
    Have you got anything connected to the composite connection on the side (red/yellow/white) ..... the composite and the component both on ext3 and it will automatically select the composite over the component, unplug it if you have and it should be fine. Other than that try checking your dvd settings mate.
  3. scoobysnack
    scoobysnack
    Feb 12, 2002
    24
    Lymington,Hampshire
    Thanks for the reply.
    I don't have anything connected to the side connections. The only connections to the panel are the component ones , a scart into input1 and the aerial.
    Scoobysnack
    PS Maybe a stupid question but i don't have to connect the dvd player to the tv via the av-receiver do i ? I assumed it's best to let the receiver just process the sound?
  4. TonyUK
    TonyUK
    Apr 8, 2006
    38
    +7
    Have you a menu within the setup of the DVD to tell it where to output?
    Perhaps if you re-connect the SCART. go into a setup menu, choose 'component', THEN plug in your component cables, it might work?
    Apologies if I'm stating the obvious or ridiculous!
    Tony.
  5. scoobysnack
    scoobysnack
    Feb 12, 2002
    24
    Lymington,Hampshire
    Sorted it. It was as simple as enabling the component output via one of the menus on the dvd player! I had discounted this as it wouldn't work with another dvd player i had but i assume this needed enabling as well!
    Thanks for the replies
    Scoobysnack
