32wl56
Discussion in 'LCD & LED LCD TVs Forum' started by areuwithmee, Jul 6, 2005.
Tags:
  1. areuwithmee
    areuwithmee
    the Toshiba 32wl56 has a hdmi input but is it Hdcp compliant?
    Toshiba says no.
  2. alefsin
    alefsin
    Feb 15, 2005
    130
    As I understand, HDCP is obligatory for HDMI so no need to worry.
    It is only the DVI connections that you should be careful with and try to see if they have HDCP or not.
