32wl56 wall bracket?
Discussion in 'Home Cinema Buying & Building' started by eagles1972, Jun 8, 2005.
  1. eagles1972
    eagles1972
    can you advise, ive just purchased the above model, iva also purchased a universal wall tilting bracket, on the back of the tv you have 4 screws to attatch to the bracket,on
    my bracket i can only connect one screw on each side(the top ones), they fit nice and tight, but will this be secure enough, or are you ment to connect all four, the only reason i cant connect all four is because the arms on the bracket dont reach far enough down
  2. Z-Trip
    Z-Trip
    You have been mis sold the bracket and should look for one that will fit it. You really need a bracket that will fit all four holes to aid the torsional integrity of the LCD.
