32WL48 wall-mounting. Oops
Discussion in 'Home Cinema Buying & Building' started by Mike246, Dec 10, 2004.
  1. Mike246
    Mike246
    Jul 31, 2004
    179
    +4
    I've just shot myself in the foot!
    I have the urge to wall-mount the 32WL48 and decided to resist Toshiba's advice to go for the Vogels bracket. It looks ever so well-made but cost a fortune.
    I saw a rather clever 'universal' system called the Omnimount distributed by Path Group. It consists of a wall-mounted frame with two horizonal rails. There are two brackets which fix to the studs at the back of the tele and hook over the rails, enabling lateral movement and tilt.
    The Omnimount is suppled in two sizes. The smaller U2 proved two short to reach the studs which are positioned close to the sides of the tele; I swapped this for the U3 which solves the problem but the wall frame is as wide as the tele so it will show at the sides.
    In retrospect, Toshiba's advice was probably good but has any 32WL46 or 48 owner identified a bracket which does the job?
  2. Deep-6
    Deep-6
    Aug 24, 2004
    150
    +5
    i must say my heart jumped into my mouth when i saw the title of your post! I had a horrific mental image of your tosh falling down ripping a big chunk of the wall with it! Glad that is not the case!!
  3. Mike246
    Mike246
    Jul 31, 2004
    179
    +4
    It would have been if I had used the samller bracket
  4. suicidal_maniac
    suicidal_maniac
    Dec 3, 2004
    58
    Mines held up by a £20 braket from b&q!....Dont worry the weight is actually sitting on my fireplace..
  5. Ultim8Fury
    Ultim8Fury
    if its a vesa 200 mounting then I can recommend the bracket I got for my sharp 45. Has a good bit of lateral movement, tilt and its very thin. Only cost £149 as well from progressive-av.
  6. Mike246
    Mike246
    Jul 31, 2004
    179
    +4
    I decided to use the Vogels bracket as recommended by Toshiba - static version so it sits up nicely in front of the wall. Not cheap but well-made and suits the Tosh.
    False wall construction in progress and will post pics when completed.
