32WL48 PC Connection
Discussion in 'LCD & LED LCD TVs Forum' started by kyle, Nov 21, 2004.
Tags:
  1. kyle
    kyle
    Hi All,
    Recently purchased a Tosh 32WL48 LCD TV, delighted with it.
    What cable do you recommend to connect a PC to it, PC has both VGA and DVI Outputs. Also where do you recommend purchasing from?
    TIA :)
  2. Deep-6
    Deep-6
    Aug 24, 2004
    151
    +5
    Hello Kyle,
    I'm on my way to PC World (i know, i know) to pick up a vga to vga cable to connect my laptop to this toshiba. If you go to www.pcworld.co.uk and search for product code: 448661
    My laptop only has vga out via the regular analogue 15 pin connector. I will let you know how it goes, maybe even post a few pics.
    Cheers,
    Mark
  3. Deep-6
    Deep-6
    Aug 24, 2004
    151
    +5
    HI Kyle, I picked up a male to male VGA cable from Belkin's High Integrity range, right up close the picture was fab and bright, but a little shimmery in places. The picture appears bang in the middle with grey bars either side. I haven't played with any settings on the TV yet or played with Powerstrip to see if I can output a resolution closer to the TV's native resolution, but so far so good.
  4. loorenzo
    loorenzo
    hi
    is it possible to connect a pc dvi to a hdmi toshiba 32wl48 ?
    thanks
