32R74bdx help!!!
Discussion in 'LCD & LED LCD TVs Forum' started by Crovon, Aug 28, 2006.
Tags:
  1. Crovon
    Crovon
    Apr 29, 2006
    5,115
    In a 4G, inverted dive, with a MIG28.
    +825
    HI guys
    up until last night my samsung was working perfectly.
    But for some odd reason it will no longer keep my settings and after about 25mins watching it changes to 'shop mode'?
    If i change the settings back to where they were it does the same thing after 25mins again.
    It just happened, I was no where near the tv and didnt touch anything, it just suddenly changed.
    Can anyone help me or does anyone know what this is/means?
    :lease:
  2. Alexlong
    Alexlong
    Mar 23, 2006
    28
    3
    Hope this helps:
    1) Turn your TV onto standby.
    2) Press Info, Menu, Mute (quickly) and then turn the Tv back on again.
    3) The service menu will now be displayed, scroll down to option 2 (Option table), then scroll down to 'Shop Mode' and switch it off.
    4) Turn the TV off and then on again and all should be well! :thumbsup:
  3. Crovon
    Crovon
    Apr 29, 2006
    5,115
    +825
    Im having trouble activating this.
    Do i hve to press all three simultaneously or one at a time?
    I have tried it one at a time after turning the tv off but when i turn it back on it just goes straight to ext1.
    cheers again.
    EDIT:
    No dont worry i have sorted it out now. Switched shop mode to off.
    thankyou very much for your help
