32pw9509: Problems
Discussion in 'Televisions' started by vivaatloni, Jun 28, 2004.
  1. vivaatloni
    vivaatloni
    I tested the 9509 4 more than a week now. My conclusion is that it is a very good set, with a beautiful image, but..........
    I have two problems:
    With some programs on terrestial (mostly on soccer, when the green field is totally in the picture ) I see white bars in the screen. At the same locations there were black bars in the older PP sets. So the white bars are in the center like a cross. Is this something other owners also noticed? Is there a cure 4 this (maybe settings ort something)? :lease:
    My second problem is that I get diagonal stripes in with my xbox connected through RGB. This is not really a fault of the 9509, cause they only occur when I connect my digital audio coax from my xbox to my reciever. (the advanced scart pack has digital coax & RGB in 1 connection). Someone knows a solution?
