32PF9986 - what shops in brum
Discussion in 'LCD & LED LCD TVs Forum' started by GazH, Jan 7, 2005.
Tags:
  1. GazH
    GazH
    Apr 17, 2004
    427
    On the corner of Wabash and Lake
    +75
    Does anyone know of any shops in Birmingham Town centre that have this TV on display.
    Gaz
  2. blossom
    blossom
    Feb 15, 2004
    1,270
    41
    Solihull
    +14
    Try Selfridges or John Lewis, Solihull.
    Paul
  3. GazH
    GazH
    Apr 17, 2004
    427
    +75
    Cheers Paul, will give Selfridges a go.. :smashin:
    Gaz
  4. ColonelK
    ColonelK
    Jan 7, 2005
    85
    Coventry
    I saw it in the bull ring before Christmas.....think it was a john lewis but can't remember
  5. steftymo
    steftymo
    Dec 14, 2004
    145
    +10
    Selfridges had one showing Sky---House Of Fraser (Rackhams) have a DVD demo - superb
    Stef
  6. GazH
    GazH
    Apr 17, 2004
    427
    +75
    Ended up not getting far from the Bullring..
    Went into Selfridges and got a very helpful assistant to show me the feeds from sky and a Bose dvd...really liked it.....my wife seemed quite impressed as well, which is always a bonus...
    Cheers all
    Gaz
  7. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Go Gaz, GO!
    Jimmy
  8. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,420
    71
    Southsea
    +69
    I can't decide whether to pick on of these up or not. The surround seems quite large (especially considering I won't be using the speakers that come with the telly). What DVD player do people suggest with this TV, I would want to connect it via DVI.
  9. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    You won't be using the attached speakers at all? Never? At the end of the day, though, the PQ is the main thing. At the £2000 (ish) mark, the Philips is currently the one. It is a big ol' thing though....but quite handsome. And then there's the Ambilight....
    HiDef DVD player most folks are talking about is the Denon 1910. It's a Denon, so you'll be OK. £250 ish outputs 720p, 1080i etc.
    Jimmy
  10. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,420
    71
    Southsea
    +69
    Yeah, I'll never be using them. I wish more manufactures made LCD with removable speakers. I think the size will be a bit to big. What are some other good choices? I wanted a sharp but can't find any unfortunately.
  11. GazH
    GazH
    Apr 17, 2004
    427
    +75
    :smashin:
    Getting good vibes mate...I really would like this TV but we can't just dive into it..... although given the chance I'd have already ordered it... :laugh:
    What are the speakers actually like...good enough for Sky Digital and standard TV I presume ????
    Gaz
  12. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,420
    71
    Southsea
    +69
    The speakers are probably its worst feature - according to the couple of reviews I've read anyway, think they lack bass or something. I'd imagine they'd be fine for general tv viewing though.
  13. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    The speakers are absolutely fine. But that's all. If you ensure that you don't pump any significant bass into them they perform admirably. Brilliant with speech and general use.
    If you want big sound you can add an active sub for very littly money, or, most likely, with a screen of this quality, you'll run a Cinema System.
    I agree that you should research this thouroughly, which is exactly what I did. I painstakingly waded through every viable TV in this sector and thouroughly tested 12 different ones. (Some more thouroughly than others) The Philips had the best picture...... It also comes with multitudes of extras which make ownership a pleasure.
    The only significant addition to the 'viable' list since I bought mine is the Toshiba 32WL48. And it isn't as good. However it is considerably cheaper and would've got my nod if my budget had been £500 less.
    Go Gaz..GO!!
    Jimmy :thumbsup:
  14. GazH
    GazH
    Apr 17, 2004
    427
    +75
    Cheers mate, as it happens I do have a cinema sound package, so I do use that for DVDs....the TV would just be for Sky, and I'm not bothered about putting that through my amp.
    One other concern I did have was the fact I would be sticking with my current DVD all in one set up (Sony DAVS300). As you might have gathered it is getting dated but I don't really want to fork out another few hundred quid on a new DVD setup (at least not initially).
    My DVD is plugged into my current TV via S-Video (DVD) to Scart (TV). As far as I'm aware my DVD player doesn't do prog scan (although I'm gonna check out the manual for what it does do), so will I get an awful picture from this until I upgrade my DVD player....or should I wait until I can upgrade everything ????
    Cheers again
    Gaz
  15. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    The s-video picture will be OK actually. I ran my Panny E55 with s-video for an hour or so before i got it hooked up properly.
    Check out your player for Component Progressive.
  16. GazH
    GazH
    Apr 17, 2004
    427
    +75
    Cheers Jim,
    Will dig out the manual tonight and see exactly what it does.
    Thanks for your help mate :smashin:
    Gaz
