32pf9986 wall bracket
Discussion in 'Home Cinema Buying & Building' started by garytreble, Feb 6, 2005.
  1. garytreble
    garytreble
    Feb 3, 2005
    126
    +13
    I've been browsing this forum for quite a while looking for advice on my new TV. I finally decided to go for the philips. I got a few questions;
    I've purchased the TV from empiredirect for for 1999. I've noticed that most retailers offer the wall bracket included. Has anyone else purchase from empire. Is the wall bracket included?
    I've read a lot about firmware. What does this mean? What version should I expect?
    Gary
  2. Alan D
    Alan D
    The 32 comes with wall bracket AND table top stand as atandard - so you should get both.
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    I got mine from Empire (4/1) and it had the 2.1 firmware.
    The firmware is the software that controls the television and enables certain hardware features. Some early models had older firmware which limited the options on the TV.
    As Alan D says the bracket and stand are part of the manufacturers bundle for that particular model so any dealer/retailer should be supplying them as a matter of course.
