32PF9986 Using DVI
Discussion in 'LCD & LED LCD TVs Forum' started by mr_fantazmo, Oct 10, 2004.
Tags:
  1. mr_fantazmo
    mr_fantazmo
    Anyone know why my new 32PF9986 & Denon DVD-A11 don't show full screen while using DVI. I think it may be to do with the resolution. :zonked: ..but use 720p and you get a small box of a picture in the middle of the screen. Use 480p or 1080i and it's a bit bigger (no side bars but still at top and bottom) but quality not as good (perfectionist).
    Because the screen is 1366 x 768 is it only using native pixels so that's why it can only show smaller images?
    T.V. is excellent by the way.
    Using Wireworld Ultraviolet 5 DVI-D Lead (about the best you can get I think).
    Mike :suicide:
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    As you also suspect, I think the screen is showing the 1280x720 dot by dot within the native 1366x768. I would expect you will get a very sharp picture compared to one scaled to fit the native resolution.
    Steve
