Can someone please confirm the 'footprint' size of the stand that comes with the 32pf9986. I've ordered a shelving unit and fear it may not be wide enough. I saw some comments, I believe from Alan, saying is about 900mm wide and about 240mm deep but I cannot find this posting anymore. Please help me, I think I've made a boo boo
Dimensions (WxDxH) 82.4 cm x 26.5 cm x 30.1 cm http://www.backoffice.be/shop/information.asp?pkga=F5A&pkgb=14
Hmmmmmmm. I had ordered a stand which was 800mm, but after that have had to change my order to a stand that is 1100mm wide. No big problem, I probably needed the bigger stand anway. Thanks for you help again jimsan, my telly turns up on Friday and i'm armed with all my cables and settings (courtesy of yourself) - can't wait.
Actually, KB, the 32" 9986 looks better on the bigger stand anyway! It looks a little top heavy on a stand that's narrower than it. Good choice. Jimmy
