32PF9986 SKY+ Remote code
Discussion in 'LCD & LED LCD TVs Forum' started by Matt Radford, Jan 19, 2005.
Tags:
  1. Matt Radford
    Matt Radford
    Hi all,
    Not sure if this has already been published on the forum, but ive managed to get the SKY+ remote programmed to operate my new Philips 32PF9986. These steps below did the trick:-
    1) Press TV on your sky+ remote
    2) Press SELECT and RED key at the same time. The red led in the SKY+
    remote should blink twice
    3) Now enter code, 584 works
    4) Sky+ remote red LED should blink twice, after code has been entered.
    4) Now point remote at TV and press standby button on sky+ remote. The
    TV should switch off
    5) Next press SELECT on the SKY+ remote and your done
    You now should be able to switch the tv back on again using the SKY+ remote by pressing the programe button. You should now be able to change the volume of your TV using the SKY+ remote.
    I prefer the philips remote myself as its a very cool remote control with the metal finish, but having the SKY+ remote working properly keeps te wife happy!!! :D
    Cheers!!
  2. neilmcl
    neilmcl
    Oct 29, 2004
    6,236
    103
    Nottingham
    +292
    Anyone know what the code is for the Sharp 32GD1E?
  3. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    The code for a 32GA4E Sharp would also be useful as the supplied sharp code doesn't work properly. Anyone know ?
  4. Friction
    Friction
    Apr 20, 2004
    7
  5. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    Thanks will check out the codes.
