M
Matt Radford
Hello All,
Im a new member to this forum!
After spending the last week reading all of your coments on the Philips 32PF9986 I decided to take the plunge and just has it delivered today!!
from TVDirect for 1926!
I must say its an excellent TV, with outstanding picture quality. Ive got it on its table stand at the moment, but I am soon getting it wall mounted!
Thanks to everyones coments I checked the firmware and it was 2.1, and managed to get my new Philips SVP720SA working with it through the component video. I would of stood no chance of working it all out without all your coments on how to do it!!!! - couldn't even work out what coloured RCA connections to make to the back of my DVD player!!!
I have a couple of outstanding questions - if anyone can help!
1) The OSD settings for on screen display seem to give you two options (Normal, Minimal). Normal - shows volume bar when you change the volume, but it also shows the channel name - EG EXT1 at the top left of the screen which I do not want to see!!! - If I switch to minimal setting on OSD then the channel name goes away but so does the volume display for when the volume is displayed!!! - Is there any way to set it up so that the volume display shows on the screen when you change the volume, but without the channel display being left in the top left corner the screen!!!!
Seems a silly question, but ive checked and cannot find the answer in the instructions, or menu options!!
2) For wall mounting with the wall bracket, I don't want the cables to be visible so I am going to get them chased into the wall, what I am not sure about is where to have them coming out? - in other words when positioning the bracket on the wall, is it best to have the cables coming out at the bottom of the screen area as thats where the sockets are, as Im worried that this would make the cables visible!!! - or is there enougth of a back when the screens mounted to have the cables coming out in the middle, so they run down from the middle area of the screen to the sockets at the bottom, with the screen resting on them!? - Im looking at chasing the power, flat quality scart, and quality component cables.
3) VGA to Component connector looks naff quality. Can a all in one Component to DVI cable be bought that would work, or do I still need to keep the DVI-VGA connector, and purchase a better quality VGA to Conponent cable, also where can I get one from, and whats recocommended?
4) Seen in leaflet that philips do a "all in one" cable that looks like a metal trunk with all the cables you need in it including power, DVI, component, scart etc, has anyone got one of these, and if so where can you get them from and are the quality of them any good!!? - I havent checked the philips website yet!!!
Sorry for so many questions - its my first Flat panel TV. PS: DVD though component/progressive scan has superb pic quality - glad I replaced my old Wharfdale DVD 750 with the new Philips DVP720SA at the same time!!!
Many Thanks!
Many Thanks!
