32PF9986 & DVI @ 1368x768
Discussion in 'LCD & LED LCD TVs Forum' started by mikearv, Dec 16, 2004.
Tags:
  1. mikearv
    mikearv
    Is anyone using the 32PF9986 with PC running a resolution of 1366x768 or 1368x768?
    The manual doesn't mention anything about 1368x768, or indeed 1366x768 being available in PC mode only 1280x768, surely though considering the panel is 1366x768 if fed that resolution it would expcept it?
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    The only way I know would be to link the panel to a PC and run a utility called Powerstrip to extend the resolution to 1366. You might not be able to get it exact but close enough (1368 or 1360).
    There should be someone on here who knows about it more than I.
    Richie.
