32PF9986 Component-VGA Cable
Discussion in 'LCD & LED LCD TVs' started by Alan111S, Feb 1, 2005.
  1. Alan111S
    Alan111S
    Oct 28, 2004
    78
    I was wondering if any 9986 owners had bought a better component - VGA cable. If so, where from and does it make any improvement?
    Am also thinking of getting a VGA Y splitter cable so I can connect my PC without moving the TV. Anybody tried that, not sure if it will knacker the VGA signal.
    Alan
  2. S Helton
    S Helton
    Oct 29, 2004
    52
    I bought one for my 9976, from Lektropacks(http://www.lektropacks.co.uk/dept.asp?dept_id=80). I needed a 10m cable and paid around £50 I think. Seems a reasonable enough cable for the price.
    If I'm honest, there is little noticable difference between the picture quality of component compared to RGB scart. Also, there are only two screen format options via component on the 9976 - 4:3 and widescreen. So if you are watching a 16:9 picture you can either have it with black bars all round or stretched out of shape!
    Never tried a VGA splitter cable, so can't help you there.
  3. Hunterm8
    Hunterm8
    Mar 5, 2003
    115
    16
    Leicester
    i have just had a look at my supplied vga-component cable for my 9986 and it has female ends whats the crack?? Is that how they all come also which colour go to which the cable is yellow red and white
  4. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Hunter, You need a separate Component cable to connect to the adapter.
    S.Helton, if you are watching a 16:9 movie it should fill the screen perfectly! Wotcha doin wrong? Quality should be better with movement - no juddering.
    Get back to us.
    Jimmy
  5. Hunterm8
    Hunterm8
    Mar 5, 2003
    115
    16
    Leicester
    jimmy could you tell me which colour goes to which?
    cheers sorry for hijacking thread
  6. chris210972
    chris210972
    Apr 23, 2004
    382
    16
    red to red
    blue to yellow
    green to white
    hope this helps
  7. Hunterm8
    Hunterm8
    Mar 5, 2003
    115
    16
    Leicester
    cheers chris
  8. S Helton
    S Helton
    Oct 29, 2004
    52
    Hi Jimsan
    Probably didn't make myself clear - an anamorphic image is displayed correctly via component. However, if I record a 16:9 format movie off the TV (onto Sony HX900 recorder), when viewed via component I can either watch it in 4:3 (which shows the black bars at the top and bottom of the image, as well as the sides) or in widescreen (which just stretches the image width, leaving the black bars top and bottom).
    If I am doing something wrong please let me know - I have a £50 cable which is not getting much use at the moment!!!
  9. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    Check the output menu on the DVD player. My Denon certainly has a 4:3 and a 16:9 output option on the component feed. This may allow your TV to display properly.
    Jimmy
  10. S Helton
    S Helton
    Oct 29, 2004
    52
    Will check tonight - thanks for your help.
  11. Peachey
    Peachey
    Jan 9, 2005
    29
    Kent
    Hi all. I received my 37pf9986 today and have a question about progressive scan connections. Hope you can help.
    The TV is v2.0 firmware so OK there and I will be connecting to a Panasonic DMR-E95. However, in the box I only received the VGA to DVI connector. I didn't receive any other cables with female connectors for hooking up my component cable. The manual says that I need a 3 cinch to VGA cable whatever that is.
    Can anyone help and tell me what cable I need to buy.
    Thanks.
    Steve
