32pf9986 cantilever wall mounts
Discussion in 'Home Cinema Buying & Building' started by gcook, Mar 17, 2005.
  1. gcook
    gcook
    Mar 9, 2005
    9
    Has anyone any advice about a decent cantilever mount to take this beauty????
    Philips Customer Care people are not only expensive but not too much help as they guided me to a few suppliers who couldnt help.
    Thnaks in advance
  2. BADA55
    BADA55
    Mar 16, 2005
    233
    +3
    Yeah try here... http://www.ricamstore.co.uk/erol.html#376x0&&
    I have ordered the twin armed model for my 26".....Ignore the tv sizes quoted coz I have already asked the company about that. Their reply was the size was purely a guide where as the max weight is the only consideration. So if your tv is less than 20kg once you take off your table stand then it will be a good mount and very reasonably priced too!
  3. gcook
    gcook
    Mar 9, 2005
    9
    Actually tried them today....very helpful guy but he thought that the 20 kgs was a bit close to the limit.
  4. BADA55
    BADA55
    Mar 16, 2005
    233
    +3
