Is there no way the 32PF9986 can take a non-progressive component signal? I was hoping to play PS2 (PAL) games using this cable instead of the composite (with scart adaptor) cable, but it seems like a non-option. Anyone wish to comment on this? http://www.monstercable.com/monstergame/ps2/productPagePS2.asp?pin=1466
Hi The PF9986 TVs do not accept non-progressive component. The best way to connect your PS2 is via a SCART cable which is wired for RGB. The standard cable/adaptor provided by Sony (on my PS2 anyway) only provides composite. QED cables do a good quality PS2 - SCART cable wired for RGB. Good Luck
