32PF9986 - A New Problem
Discussion in 'LCD & LED LCD TVs Forum' started by Barrovian, Mar 6, 2005.
Tags:
  1. Barrovian
    Barrovian
    Oct 29, 2002
    1,408
    United Britain of Great Kingdom
    +376
    Finally took delivery of my 9986 yesterday. I love the set, but I think it's going back to John Lewis.
    Not only does it suffer from contrast 'humming' as detailed in other threads, but worse than that, the picture from all sources, i.e. DVD (RGB), Sky (RGB), VHS and analogue terrestrial is affected by a sort of vertical rolling shimmer. It's very noticeable, so much so that my wife noticed it the moment she sat in front of the set. A bit like heat haze ( and no, it's not above the fireplace )
    Has anyone else come across this? I'll probably get JL to exchange it, but if it's a known problem, I'll cut my losses and get a refund.
    I'm gutted as I was so looking forward to getting this set.
    John
  2. Alan D
    Alan D
    I've not heard about "vertical rolling shimmer" before - unless you have a faulty cable that is leaking signal from another source. Does it do it only when, say, Sky is swtiched on? Or is it all the time?
  3. Basil
    Basil
    Whilst I wouldn't rule out a fault, I tend to agree with Alan. Could the cables be wound around a mains cable, or maybe near an R.F. source (a video sender perhaps?)
    I recently solved a picture quality problem (a V. Faint blue/cold tinted picture) by changing cables for better quality ones - Do your cables have individualy shielded cores, or ar they overall shielded?
  4. Alan D
    Alan D
    I mention the cables John because I had a problem initially with a "leaky" Scart lead and occasionally I would get some interference (like a vague ghostly picture) from Sky when I was watching DVDs. I changed my cables around and the problem went. I wonder if you could to isolate it by turning off different sources to see if it goes away.
  5. Exirion
    Exirion
    Mar 4, 2005
    148
    Eindhoven
    +6
    I bet this is interference. Do you use a cheap SCART cable? Those don't have shielded wires witin the cable so there is interference between the wires. I have exactly the same thing with my 9976 :) A better cable will probably solve this, so first try a better cable before returning the TV ;)
  6. Barrovian
    Barrovian
    Oct 29, 2002
    1,408
    +376
    Hi Alan & Basil,
    Thanks for the replies. I've not had chance to check the cables, it's been 'Mother-in-Law Day' :)
    I'll try what you suggest and post back.
    cheers,
    John.
  7. Exirion
    Exirion
    Mar 4, 2005
    148
    Eindhoven
    +6
    :boring:
  8. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    I guess postings crossed in the ether...
  9. Exirion
    Exirion
    Mar 4, 2005
    148
    Eindhoven
    +6
    You're right... And I shouldn't act like a whining kid due to a bad day :D
  10. Barrovian
    Barrovian
    Oct 29, 2002
    1,408
    +376
    .. and thanks for your considered reply, Exirion! ;)
  11. Barrovian
    Barrovian
    Oct 29, 2002
    1,408
    +376
    Well, I've done as suggested and disconnected everything except the mains lead and the aerial, and the flicker is still there. I therefore must suppose a fault with the TV.
  12. Camillo
    Camillo
    Jan 14, 2005
    22
    3
    Actually, it's possible to get a ground loop even with just the mains and the aerial. It depends on if you have the aerial in the same ground as the mains. Altough it's probably not the case this time, you can easily test it.
    Use the DVD-player via RGB SCART only, and do not connect the aerial at all. Make sure you connect both the DVD player and the TV set to the same mains connection.
  13. lz1cam
    lz1cam
    Hi JP,
    I guess you muat had another TV set before buying the LCD.
    Why don't you try the old one with the same configuration?
    Greetings
  14. Diamara
    Diamara
    Jan 5, 2005
    23
    I had this problem and found that I was getting interference from my Wi-Fi network. Moved the wireless access point away from the TV and the picture cleared up.
  15. Barrovian
    Barrovian
    Oct 29, 2002
    1,408
    +376
    Thanks, Camillo. Tried it, but no luck I'm afraid. Interference is sill there.
    And Iz1cam, the set was a straight swapout replacing my old CRT. No problems before.
    JL delivering replacement on Saturday.
    Keep you posted.
    John.
  16. Barrovian
    Barrovian
    Oct 29, 2002
    1,408
    +376
    JL delivered the replacement last Wednesday. As soon as the set was switched on, it was obvious that it's another 'Hummer'. The picture 'flicker' is still there, but now affects the entire screen, not just the left hand side as before (although I didn't make that clear in earlier posts). I tried to 'live' with those problems, but I find myself looking for them all the time, and that really spoils it for me. What's really done for the replacement though, is whilst watching a 2.35:1 ratio DVD at night on Friday, it became obvious that the backlight is uneven. The top right hand corner displays a visibly lighter patch than the rest of the screen, which projects towards the centre. Very distracting. So, I'm afraid, this one is going back as well. John Lewis cannot be faulted for their customer service, they're collecting the set next Saturday for a full refund. I love the set, but at the end of the day, I can't justify spending £2K on a set I know I'll never enjoy because of the flaws.
    John
