32pf9976
Discussion in 'LCD & LED LCD TVs Forum' started by aldergrove, Oct 20, 2004.
Tags:
  1. aldergrove
    aldergrove
    New to the LCD world and looking to buy.
    Wife dont like the 9986 so its out the window, From various web trips it looks like the 9976 is the same bar the abmiant light (bit she dont like, too big).
    Open to comments and guidence from fellow members.
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
  3. jdl
    jdl
    Feb 4, 2004
    139
    Athens Greece
    +3
    HA HA HA HA :rotfl:
    Nice one Ianh64 :smashin:
  4. aldergrove
    aldergrove
    Sorry I thought this was a technical forum?
    Any constructive comments gents??
  5. LiquidB
    LiquidB
    May 25, 2004
    93
    +19
    You won't be disappointed. I'ts got good video processing comparable to the 9986, but only misses the ambilight and the nxt speakers.
  6. aldergrove
    aldergrove
    Thanks LiquidB, do you have one? As I was wondering what the difference is between the 76 & the 56, the 56 is dearer wherever I have looked?
    Still had nothing back from Philips on the matter!
  7. LiquidB
    LiquidB
    May 25, 2004
    93
    +19
    The 56 has a memory card reader and USB slot and different IO capabilities: HDMI iso DVI and no component input possible (in the 9986 it is possible via DVI)
  8. LiquidB
    LiquidB
    May 25, 2004
    93
    +19
    Forgot to mention the 56 can't handle 720p, 1080i, SVGA and XGA signals.
    The 86 can (although there is the blackbar issue on 720p and XGA, see other posts)
  9. Hopeful
    Hopeful
    The 76 can't handle these either - long call with Philips customer services as I was thinking about getting either the 76 or the 56 as I also have an issue with the styling of the 86. Have consequently given up and will go for the 86 anyway as I can't live with the inferior signal support.........
  10. LiquidB
    LiquidB
    May 25, 2004
    93
    +19
    They couldn't be more wrong. idiots
    It DOES support the standards. Trust me on it.
  11. alfie786
    alfie786
    Oct 22, 2004
    118
    London
    where is cheapest place for the 76 , i do like phillips they look v nice.
    Im thinking of the 46 too as i have a limit budget £1300 but will the 46 be as good as the other mentioned?
    or what hsould i be lookin at instead/.
  12. aldergrove
    aldergrove
    can i clarify do either the 76 or 56 support the following
    HD
    Prog scann
    componant in
  13. duffer
    duffer
    Nov 8, 2004
    193
    Vicenza
    +6
    Hello aldergrove, did you find out the answers to yr last Q?
  14. ANTHONYVEE
    ANTHONYVEE
    I just got the 32PF9976. I am very pleased in general, it made my small living area look larger. The 86 is a better set but will cost another 500UKP..
    The 76 fits nicely on a wall and looks neutral
  15. duffer
    duffer
    Nov 8, 2004
    193
    Vicenza
    +6
    What do you think of the picture on normal terrestrial TV and that of DVD? My complaint with this LCDTV is that everything looks like a documentary, even DVDs look like they were filmed on video!
  16. po_man
    po_man
    Dec 23, 2004
    1,710
    St Albans
    +63
    Hi aldergrove
    Just thought i'd mention that 32PF9976 has Pixel Plus 1 technology, whereas the PF9986 actually has Pixel Plus 2 and does have a superior picture - so the difference isn't just the ambilight.
  17. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Shame about your wife's opinion on the looks of the 9986. The ambilight is utterly brilliant and the set looks brilliant on the right stand in the right place.
    ALSO, and this is a biggie...the 9986 has PixelPlus2 and all the others mentioned above don't.
    This is really quite important as this lifts the 9986 above all the rest when it comes to the crucial matter of Picture Quality.
    Depends how much this matters to you...
    Jimmy
    Mine is on a Kenmark stand that cost just £199 from Comet.
