32pf9976 Sound proplem !!!
Discussion in 'LCD & LED LCD TVs' started by jimba, Apr 13, 2005.
  1. jimba
    jimba
    Picture is amazing but it seems that the sound is slightly out . Its like watching an old kung-fu movie . Has anybody got any ideas how to fix this .
    Its got all good leads connected. and runs through a sky digi box and dvd/surround system.
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Is the sound OK? Is it just that it is out of sync?
    If it is a sync problem try using the phono output from the TV into the Surround amp. This connection uses the TV's own Sync correction technology.
    Jimmy
  3. jimba
    jimba
    is a sync problem. will try what you said and let you know the results. Cheers
  4. Robert Hill
    Robert Hill
    Oct 8, 2004
    71
    Well, I've had to use spare amp + speakers anyway, as the one on the 9976 are suprisingly poor! I've now noticed a slight buzzing from the top of the casing now. I seem to recall earlier posts on this matter....something about reducing the contrast levels was it?? The 9976 I have is in the conservatory so trhe buzzing has started since its got a bit warmer, so I wonder whether expansion of plastic etc is causing this!
    Robert
