32PF9976 - Can you disable automatic input sensing?
Discussion in 'LCD & LED LCD TVs' started by ugurevin, May 11, 2005.
  1. ugurevin
    ugurevin
    When I eject my DVD connected to EXT2, TV switches from EXT1 (SKY) to EXT2 as if I turned on DVD device. Is it possible to disable automatic input sensing feature? In other words is it possible to switch the source manually "only"?
    Regards,
    Ugur
  2. nal
    nal
    May 24, 2003
    Cutting the wire to pin 8 on one of the scart ends will stop it switching.
