32PF9830 vs 42WLT66
gcwebbyuk
I am currently renting a Philips 32PF9830 TV, which I am very happy with...
...although I have just found out I could rent the Toshiba 42WLT66 for the same money!
How do the two TVs compare?
I have Sky+ so am not worried about off-air broadcasts.
I have an Xbox and a HDMI DVD Player.
All thoughts would be greatly appreciated
gcwebbyuk
Just worried if it is actually as good a tv - or if it is just BIGGER.
Measured it up, and the 42 is basically same physical size as the Philips, just that the Philips has a massive bezel for the nxt speakers.
gcwebbyuk
I have been lucky with the 9830. although it was swapped over 2 weeks after installed. new one is fine though.
is the tosh as good for pict quality, not fussed about sound as I have tosh sd44hk.
