32PF9830 top buttons
Discussion in 'LCD & LED LCD TVs Forum' started by onelife2000, Oct 23, 2005.
Tags:
  1. onelife2000
    onelife2000
    Oct 21, 2005
    251
    +22
    32PF9830 top buttons...
    Are the buttons supposed glow on the top? Mine don't - I know the old version did...?
  2. Phill_1981
    Phill_1981
    Feb 14, 2005
    1,574
    Woking, Surrey
    +44
    on the 9986, there is an option in the menu to toggle on or off - not sure about the 9830...
  3. ACMErubberDuck
    ACMErubberDuck
    May 26, 2005
    123
    Dublin
    Mine don't either.
  4. onelife2000
    onelife2000
    Oct 21, 2005
    251
    +22
    Interesting... if your's are not working either... perhaps they removed the backlights and the motion sensor.
    From the 9986 PDF manual:
    Intelligent lights
    Select Yes if you want the blue lights in the keys on top of the TV to illuminate (for a few seconds) when somebody is within 1-1,5 m of the TV.
    Note: As the Intelligent lights function based on reflection of moving objects, they will perform differently dependent on the environment and type/colour of clothing worn.
    Don't mind if they don't on the 9830, just wann know if they are supposed to. Hey After all I got a remote control stand! Prob is I always wanted a flat screen to put on the wall!
  5. Digitised
    Digitised
    Oct 11, 2004
    177
    +13
    i found it really annoying to have it one since its distracting. You have to be pretty close (2ft) to make them detect you, but when you turn lights out and watch films the ambilight sets it off every 10 seconds.
    if its off the 9830 then thats only a good thing, i also hope theyve removed the bright blue LED power light from the front, that is equally as distracting.
  6. onelife2000
    onelife2000
    Oct 21, 2005
    251
    +22
    blue LED power light - nope still there. could use a big sticky plaster I suppose :)
  7. onelife2000
    onelife2000
    Oct 21, 2005
    251
    +22
    Finally got and answer from phillips....
    With regards to your query we can advise that the light on the top of
    the television that had motion sensors that was a function on the 9986
    has been removed and is not a feature on the 32PF9830/10.
    least I know it's not broken!
