32pb50, what do I do ,keep or replace?
Discussion in 'General TV Discussions Forum' started by romored5, Mar 10, 2002.
  1. romored5
    romored5
    I have a Tx32pb50 which has been away for repair due to the buzzing problem.
    Well it came back and at first I noticed no difference , after a short while however I noticed that the buzzing now stops after the set warms up (say about 1hr)
    The question is this, do I get it replaced (I'm waiting for a replacement at the moment) and risk getting a set which will buzz all the time as it would not of had the modification which my one has
    or
    do I cut my losses and keep the current set which in every other way is fantastic
    WHAT DO I DO??????????............HELP !!!!!
  2. romored5
    romored5
    come on guys and girls
    any thoughts or opinions ?
  3. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Is it new?
    If I were you I would exchange it for the new one, and if that one buzzes then keep complaining/changing until you get one you are happy with - I would never accept sub-standard equipment! You are paying enough for it after all!
