32nx200 - audio and video connections...
Discussion in 'TVs' started by neeshman, Apr 19, 2003.
  1. neeshman
    neeshman
    i have a sony dav-s300 dvd player (which is one of the older ones), which doesnt have a scart connection for video, only s-video. What would be the best way to connect to the tv. I saw that the 32 nx200 has svideo, but it is located on the front panel. I would like to know of a better way of connecting the tv up to the dvd player ( i do not have the tv yet, only saw it in comet today)...
    Also how would i hook up the audio? does the tv have an optical output, because i think the dvd has an optical input (which presumably is the best way of connecting audio...)
    i am completely new to this so people who have the tv (as well as any others) please explain as much as possible...
    thanks a lot.....
    neeshman :smashin:
    p.s this is the spec of the dvd player:
    http://www.sel.sony.com/SEL/consumer/ss5/home/homeentertainment/dreamsystems/dav-s300_specs.shtml
  2. neeshman
    neeshman
    no-one????
  3. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
  4. neeshman
    neeshman
    will this give the optimum audio settings?
  5. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    It will simply take the normal 'stereo' audio direct to the tv in ADDITION to the davs' own speaker system.
    Either have the tv vol turned down and use the davs speakers for full home cinema, or alternatively you could listen to the audio via the tv's internal speakers.
  6. neeshman
    neeshman
    do you know anything of the optical audio settings on the tv? (are there any?)
    cheers
