32ld7200 - which wall mount?
Discussion in 'Home Cinema Buying & Building' started by Ringofan, May 2, 2005.
  1. Ringofan
    Ringofan
    Apr 3, 2005
    9
    3
    Hi everyone,
    OK, hopefully a fairly straightforward question - which wall mount(s) are compatible with the Hitachi 32LD7200 & where can I get the best deal on one (oops, sorry that's 2 questions). I didn't buy one with the set as the retailer wanted £150 & I figured there must be a better value option - was I kidding myself?!?
    I had been toying with this mount:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=5770381188&rd=1&sspagename=STRK:MEWA:IT&rd=1
    but having checked the back of the panel & seen that it isn't entirely flat I'm not sure it will fit.
    Please help! :lease:
    I'd love a variable tilt mount if at all possible, fixed tilt as a second option or flat as a third (the TV will be going above the mantlepiece so I'm assuming a variable tilt will be my best option.
    Thanks in advance.... :)
    Ringofan.
