32ld7200 help
Discussion in 'LCD & LED LCD TVs Forum' started by rossscott, Sep 9, 2005.
Tags:
  1. rossscott
    rossscott
    Hi All
    Can anyone help me connect my sony vaio laptop to my screen please.? Here is what is happening. I can get it to display the winxp bootup logo but when it comes to the windows login screen the screen just says out of sync. I have set my res on the laptop to be everything from 800x600 and up to 1024x768 but still get the same error.
    I also went into setup menu on the screen and enabled WXGA but not sure if this was the correct thing to do. My laptop can support 1400x1080 ...
    Any help appreciated
    Ross
  2. daz1976
    daz1976
    Jul 13, 2005
    138
    Norwich
    +21
    If you look on the massive 7200 thread on here somewhere you'll find plenty of info in there about connecting a PC. Would offer advice but can't remember myself :)
    Daz
