32LC3R Owners in here please
danswan
Hello
After trying and failing fairly miserably to get some advice here I decided to change tack a bit
I was wondering if anyone who has this TV and is connected to their PC via DVI -> HDMI could have a look at their EDID information and post it on here for me? There seems to be plenty of programs that would do this, but I used Moninfo.
I'm hoping to be able to use something like Phoenix to just edit my EDID which would hopefully limit the possibility of me completely ballsing up my new telly.
If you can't be bothered to read the thread above, basically the TVs EDID info is wrong when connected to HDMI, which is stopping me from getting 1360 * 768 1:1.
I would really appreciate the help and it should only take a couple of minutes.
Thanks!
danswan
Here's my problem moninfo when connected via DVI -> HDMI:
Monitor
Windows description......... Plug and Play Monitor
Manufacturer description.... 32LC3R-ZJ
Manufacturer................ LGE
Plug and Play ID............ GSM7588
Serial number............... n/a
EDID data source............ I2C bus (real-time)
Manufacture date............ 2006, ISO week 12
EDID revision............... 1.3
Display type and signal..... Digital
Sync input support.......... n/a
Screen size................. 920 x 520 mm (~44")
Power management............ n/a
Color characteristics
Display gamma............... 2.50
Red chromaticity............ Rx 0.655 - Ry 0.331
Green chromaticity.......... Gx 0.258 - Gy 0.667
Blue chromaticity........... Bx 0.148 - By 0.062
White point (default)....... Wx 0.281 - Wy 0.297
Timing characteristics
VESA GTF support............ Not supported
Horizontal scan range....... 25-50kHz
Vertical scan range......... 45-65Hz
Video bandwidth............. 80MHz
Extension blocks............ 1
Timing recommendation #1.... 720x480 at 60Hz
Modeline................ "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Timing recommendation #2.... 1920x540 at 60Hz
Modeline................ "1920x540" 74.250 1920 2008 2052 2200 540 542 547 562 +hsync +vsync
Timing recommendation #3.... 1920x1080 at 30Hz
Modeline................ "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Timing recommendation #4.... 1920x540 at 50Hz
Modeline................ "1920x540" 74.250 1920 2448 2492 2640 540 574 579 562 +hsync +vsync
Timing recommendation #5.... 1920x1080 at 25Hz
Modeline................ "1920x1080" 74.250 1920 2448 2492 2640 1080 1148 1158 1124 interlace +hsync +vsync
Timing recommendation #6.... 1280x720 at 50Hz
Modeline................ "1280x720" 74.250 1280 1720 1760 1980 720 741 746 750 +hsync +vsync
Timing recommendation #7.... 720x576 at 50Hz
Modeline................ "720x576" 27.000 720 732 796 864 576 581 586 625 -hsync -vsync
Timing recommendation #8.... 1280x720 at 60Hz
Modeline................ "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Standard timings supported
720 x 480 at 60Hz - LGE
720 x 576 at 50Hz - LGE
1280 x 720 at 50Hz - LGE
1280 x 720 at 60Hz - LGE
1920 x 540 at 50Hz - LGE
1920 x 540 at 60Hz - LGE
1920 x 1080 at 25Hz - LGE
1920 x 1080 at 30Hz - LGE
Raw EDID base
00: 00 FF FF FF FF FF FF 00 1E 6D 88 75 00 00 00 00
10: 0C 10 01 03 80 5C 34 96 0A F3 30 A7 54 42 AA 26
20: 0F 48 4C 00 00 00 01 01 01 01 01 01 01 01 01 01
30: 01 01 01 01 01 01 8C 0A D0 8A 20 E0 2D 10 10 3E
40: 96 00 C4 8E 21 00 00 18 00 00 00 FC 00 33 32 4C
50: 43 33 52 2D 5A 4A 0A 20 20 20 00 00 00 FD 00 2D
60: 41 19 32 08 00 0A 20 20 20 20 20 20 00 00 00 00
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 F6
Raw EDID extension (CEA-861)
00: 02 03 1C 72 23 09 07 02 49 07 16 81 03 05 14 13
10: 12 04 83 01 00 00 65 03 0C 00 10 00 01 1D 80 18
20: 71 1C 16 20 58 2C 25 00 C4 8E 21 00 00 9E 01 1D
30: 80 D0 72 1C 16 20 10 2C 25 80 C4 8E 21 00 00 9E
40: 01 1D 00 BC 52 D0 1E 20 B8 28 55 40 C4 8E 21 00
50: 00 1E 8C 0A D0 90 20 40 31 20 0C 40 55 00 C4 8E
60: 21 00 00 18 01 1D 00 72 51 D0 1E 20 6E 28 55 00
70: C4 8E 21 00 00 1E 00 00 00 00 00 00 00 00 00 2F
EIA/CEA-861 Information
Revision number............. 3
DTV underscan............... Not supported
Basic audio................. Supported
YCbCr 4:4:4................. Supported
YCbCr 4:2:2................. Supported
Native formats supported.... 2
DTV formats supported....... 3
CE standard timings supported
720 x 240p at 59.94/60Hz (16:9) - Doublescan
720 x 480i at 59.94/60Hz (16:9) - Doublescan
720 x 480p at 59.94/60Hz (4:3) - EDTV
Display adapter
Adapter description......... RADEON X800 Series
Adapter device ID........... 0x554D1002
Display settings............ 1360x768, 32bpp
User/computer information
Registered user name........ Media Centre
Registered organization..... n/a
Network user name........... Media
Network computer name....... MEDIA-1EACDBFD2
Windows version ............ Windows XP
Windows build .............. 5.01.2600 Service Pack 2
Installation date .......... 1/9/2007 12:00:00 PM
And heres my moninfo results when connected via VGA:
Monitor
Plug and Play ID............ GSM7587
Serial number............... 9509 (161209509)
Display type and signal..... Analog 0.700,0.300 (1.0V p-p)
Sync input support.......... Separate
Screen size................. 700 x 390 mm (~33")
Display gamma............... 2.20
Red chromaticity............ Rx 0.640 - Ry 0.341
Green chromaticity.......... Gx 0.287 - Gy 0.610
Blue chromaticity........... Bx 0.146 - By 0.069
White point (default)....... Wx 0.285 - Wy 0.293
Horizontal scan range....... 31-50kHz
Vertical scan range......... 58-63Hz
Video bandwidth............. 90MHz
Extension blocks............ n/a
Timing recommendation #1.... 1360x768 at 60Hz
Modeline................ "1360x768" 84.750 1360 1432 1568 1776 768 771 776 798 -hsync +vsync
Timing recommendation #2.... 1280x768 at 60Hz
Modeline................ "1280x768" 80.140 1280 1344 1472 1664 768 771 778 798 -hsync -vsync
640 x 480 at 60Hz - IBM VGA
640 x 480 at 60Hz - VESA
720 x 400 at 70Hz - IBM VGA
800 x 600 at 60Hz - VESA
1024 x 768 at 60Hz - VESA
1280 x 768 at 60Hz - LGE
1360 x 768 at 60Hz - LGE
Raw EDID base
00: 00 FF FF FF FF FF FF 00 1E 6D 87 75 25 25 00 00
10: 0C 10 01 03 08 46 27 78 0A D9 B0 A3 57 49 9C 25
20: 11 49 4B A1 08 00 31 40 01 01 01 01 45 40 01 01
30: 61 40 01 01 01 01 1B 21 50 A0 51 00 1E 30 48 88
40: 35 00 BC 88 21 00 00 1C 4E 1F 00 80 51 00 1E 30
50: 40 80 37 00 BC 88 21 00 00 18 00 00 00 FD 00 3A
60: 3F 1F 32 09 00 0A 20 20 20 20 20 20 00 00 00 FC
70: 00 33 32 4C 43 33 52 2D 5A 4A 0A 20 20 20 00 07
Display adapter
Steve1951
First let me say I cannot help with your problem directly but.............
The title .......It is not immeadiately obvious what make this is... reading on I see its an LG.I suggest you EDit the title to include this.
The Question......In my experience of this site most people are pretty knowledgeable but there is a limit!
I HAVE read replys from professional engineers which is what I think you need here.
I would love to help but its way above my head and I think you might struggle to get such specific and complicated info.
Good Luck Anyway
Steve
danswan
Thanks for the reply Steve
All I am asking is that someone who owns this TV, and is connected via DVI->HDMI runs moninfo or a similar program and posts the results here, that will then hopefully give me the information I need. I don't think this is beyond most people is it?
RockySpieler
I think you would be best off, experimenting with Powerstrip custom timing before you try and re-write your EDID chip.
The link you gave to tucows for the Phoniex program, doesn't have much support, whereas Powerstrip is a widely used ultility with many support sites.
I use PS and find it excellant with my 32" Medion LCD, I have desktop icons, so I can easily switch between 50hz, 60Hz and 48Hz, depending on the framerate of the video I'm watching.
danswan
Thanks for the reply rockyspieler
I have been experimenting with powerstrip for the past few days, I have no problem with the graphics card outputting 1360x768 but I have been informed that the reason for my problem is the EDID. There's people with similar problems on the powerstrip forum who say that rewriting their EDIDs was the only thing that fixed it.
Apparently the thing to do is to edit the EDID in phoenix and upload it back to the TV using powerstrip.
But to edit it I need to see what a working EDID looks like, therefore once again could I ask if anyone could upload their working EDID here?
RockySpieler
have a bump...........
Good Luck hopefully an LG 32LC3R owner will see your request.
jeromeof
I have this telly, but I have not connected the PC to it via DVI/HDMI. I have connected it via DVI/VGA cable into the RGB (don't know why they call it this) on the back of the telly. It works excellently well giving me 1360x768 1:1.
So my question to you is why connect it this way? I am going to be using the HDMI interface for Sky HD (which I am going to get connected in a few days hopefully).
Jerome
danswan
Hi jeromeof (and thanks for the bump RockySpieler)
I have it connected via VGA at the moment, and the picture quality is indeed excellent. There are a few reasons I want to use DVI-HDMI, firstly I have tried both and I like the black (or backlight) control that I have over HDMI. Also I have bought a 5m DVI-HDMI cable as the TV will be some distance from my media center box once I mount it on the wall.
Lastly (but not leastly) I know this should work, I bought this TV because I knew it to work over HDMI at 1360x768 and that's what I want it to do!
Having said that, as I appear to be getting nowhere with the EDID route I am considering calling LG support at the weekend - something is surely wrong when my 32", 1366x768 panel is reported as a 44", 1920x1080 screen?
Also, I'm still not sure how to edit the title of this post as it appears from the main forum screen, I want to change it to LG 32LC3R & LG 32LC2D owners in here please, as I know the panel in the 32LC2D is the same as is used in my 32LC3R.
F
Floppe
Hello!
I've bought an 32LC2D this summer and now I'm building myself MythTV system and wonders if anyone has a working xorg.conf or modelines for this telly?
// Floppe
