32fx66 Save speakers off setting
Discussion in 'General TV Discussions Forum' started by kearneyt, Jan 30, 2003.
  1. kearneyt
    kearneyt
    Jan 29, 2003
    13
    Firstly, I have the 32fx66 and it buzzes like hell( hope to have an engineer out or TV going back)
    On the buzzing, my opinion is that as some tv's do not have this 'design feature' then it is clearly a faulty component. As long as one of these tv's do not make this noise then we should have the faulty component replaced.
    My main question is how do I save the 'speakers off' setting so that I do not have to keep changing it when I turn on my tv. I am using an amp and this is very annoying.
    Thanks for any help.
    Tom.
  2. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    There is no option, you will have to-do that everytime you turn your TV on.
    I have the same problem and i think its a flaw in this TV.
    Dal :blush:
  3. Mark Spanner
    Mark Spanner
    Dec 11, 2002
    264
    Norfolk, UK
    +5
    Just turn the volume to nothing.
    I find that it is the same which begs the question - if is is the same as speakers off why have the option?
    It's still very annoying that it doesn't save.
    My FX66 buzzes like hell - gonna have get them to replace the part (if it is that - look at thread 'Sony buzzing solved'.)
    Also get the engineer sort out the geometry, convergance etc.
  4. kearneyt
    kearneyt
    Jan 29, 2003
    13
    The setting 'speaker off' still has to be set even if you lower the volume because this setting switches on the external left/right output to the Amp.
  5. Mark Spanner
    Mark Spanner
    Dec 11, 2002
    264
    Norfolk, UK
    +5
    Sorry didn't know - I use digital optical from other sources.
    Well that is extremely annoying. :mad:
    Maybe it is something that can be fixed via the service menu or engineer.
  6. kearneyt
    kearneyt
    Jan 29, 2003
    13
    Is it possible to take the sound from a sky digital decoder straight to the AMP thus bypassing the TV and this way I could just leave the volume at zero. My dvd player goes straight to the Amp (optical) so I have no problem there.
    It's amazing that Sony have not thought of alowing this setting to be saved as the reason people would do it in the first place is because they have an AMP connected and are likely to have this setup permanently.
    Maybe they were afraid of service calls regarding complaints about 'no sound' because people would save this setting by mistake?
    Thanks for you help,
    Tom.
  7. Rookies
    Rookies
    Jan 4, 2003
    5,630
    +532
    There should be no problem at all doing it that way.
  8. kearneyt
    kearneyt
    Jan 29, 2003
    13
    Thanks. What do I do? get a SCART breakout and connect the left and right audio to the Amp? Are these available? I don't see any other audio outputs on the sky decoder.
    Thanks for all the help,
    Tom.
  9. Rookies
    Rookies
    Jan 4, 2003
    5,630
    +532
    Why dont you just connect the white and red audio jack at the back of sky to audio jack on your amp?
  10. kearneyt
    kearneyt
    Jan 29, 2003
    13
    Thanks Rookies but maybe sky are doing us Irish out of these connectors as I don't seem to have them?
    Maybe I missed them as I was squeezing my head around an irritating buzzing sound from my Sony TV :))
    I will check again tonight.
  11. kearneyt
    kearneyt
    Jan 29, 2003
    13
  12. HowieC
    HowieC
    Jun 9, 2002
    251
    London
    I take the audio from scart3, the fact that there is a setting on the menu for the scart3 output suggests that sony expects it to be used this way. The speaker off situation is bizzare however.
