32DX200 optical out
Discussion in 'General TV Discussions Forum' started by machasm, Sep 30, 2004.
  1. machasm
    machasm
    Sep 17, 2004
    25
    3
    Hi Guys,
    I have recently purchased a Sony 32DX200 and have tried to connect the optical out to my 5.1 decoder but there seems to be no output from the set although there is an LED shining from the output.
    Can anyone confirm whether the optical out actually works on this set?
    Thanks.
    Mac.
  2. Grif
    Grif
    Jul 28, 2004
    269
    +4
    Oh crud....I hope so. I've just got this set too and was planning to link it up in the same way.....waiting for a cable to turn up. Its described as an SP-DIF Optical Audio Output in the Sony Tech spec leaflet.
    Have you definately got all the right buttons pushed on your amp? If you have I would call Sony or drop them an e-mail.
  3. machasm
    machasm
    Sep 17, 2004
    25
    3
    I have phoned my local Sony centre and asked them to check it with the one in the shop they have. They haven't got back to me yet.
    My 5.1 decoder is new and I haven't tested the optical in yet but will try my PC (it has optical out) with the setup after work just to make sure.
    That said, the coax and direct inputs work on the amp.
    Mac.
  4. Grif
    Grif
    Jul 28, 2004
    269
    +4
    Would be grateful if you would post your finding on here...I will do the same when the cable arrives.
    Grif
  5. machasm
    machasm
    Sep 17, 2004
    25
    3
    According to my local Sony centre the optical out DOES work but only when using the in-built tuner.
    So if you have anything connected using the Scart sockets or other external source then there is no optical out.
    This sucks for me since I am using a sky digibox which has no digital sound output.
    Mac.
  6. Grif
    Grif
    Jul 28, 2004
    269
    +4
    That should'nt be a problem Mac.....your digibox should have 2 phono analog outputs....just plug'em in to your amp....this is what I was going to do . I only wanted opt out for freeview anyway so does'nt bother me too much...although it does seem daft.
  7. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    The reason is probably something to do with the fact that an IDTV such as this one is only receiving DIGITAL audio from the DTT transmission, the signals input via scart or other connections will be analogue and would therefore require some kind of digital audio encoder. And since many digital sources such as Sky boxes and DVD players already have a digital-audio-out it probably doesn't make much sense to duplicate this function in the TV.
  8. Grif
    Grif
    Jul 28, 2004
    269
    +4
    Makes perfect sence Mr Headache...
  9. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    Easy to say but would you really pay more for your TV just to have your analogue audio source coming out of the TV's digital connection when it already comes out of the analogue audio output?
  10. Grif
    Grif
    Jul 28, 2004
    269
    +4
    Uuuuurr....think we are now talking cross purposes.....what I meant was, that your post made perfect sense (i.e I understand what your saying and concur). My fault for using the word sense I suspect (and infact spelling it incorrectly).
  11. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    Oops! Sorry my missunderstanding! :blush:
  12. Grif
    Grif
    Jul 28, 2004
    269
    +4
    No worries :)
