329617 Pixel Plus from Sound and Vision
Discussion in 'General TV Discussions Forum' started by PrinceOfEgypt, Apr 28, 2002.
  1. PrinceOfEgypt
    PrinceOfEgypt
    Mar 28, 2002
    358
    London
    +14
    Dear All,
    You have probably read all the troubles i have had with Sound and Vision in Bolton.
    I recieved my philips 329617 a few days ago. Initially i was impressed with it, but the picture was no way near the quality as the set i saw on display in comet.
    The corners are bent, it has dark patches etc.
    Very disillusioned i looked on this forum for answers only to find that i have the panasonic tube!
    After giving back the panasonic TV a few weeks ago, i have now got a philips case with a panasonic tube in it.
    IM TOTALLY FED UP WITH EVERYTHING...
    I am going to call up Sound and Vision and ask for replacement or a refund today, because this is the worst nightmare...
    ROY at sound and vision please help, i want a philips tv not a hybrid panasonic tv.
    Many thanks...
    PrinceOfEgypt...
  2. Paul D
    Paul D
    Dec 27, 2000
    2,794
    Manchester
    +557
    Though you may not believe me(due to other posts etc), but i have real sympathy for your situation. :(
    You have spent a large amount of money, and you have still not got a TV you are happy with. I had a similar problem with Toshiba's first "real flat" TV. The dark patches were just not acceptable.
    I had this swopped for a Panasonic 36PF10. Although most of the dark patches were gone on this set, it had other minor defects.
    One problem was a Moire effect on some material, another was a problem with chroma delay via RGB. I posted here about these problems at first. But found that as i settled into watching things, i stopped focusing on them.
    The trouble is that we tend to examine our new TVs with a fine toothcomb. Looking for any defects, which we wouldn't normally see on normal viewing.
    Once we find them, we cannnot help but feel as if we have a dud.
    Most new TV's have small bends somewhere on the screen, it's a CRT trait. As for the dark patches, yes my TV has a small patch on the lower right hand side. It looks as if somebody has been a little to near with a magnet etc. I notice it now and then, but since it's only a small defect i just accepted it.
    I am not saying your faults are acceptable. Only you can decide if you could live with them etc. It just that you can go mad with CRT TVs trying to get a perfect model!.
    Anyway good luck with getting a replacement/refund.
    Post back...good or bad, about S&Vs responce etc
    Paul
