32" with 1280 x 768 res ? (need a quick reply pls)
Discussion in 'LCD & LED LCD TVs Forum' started by Phill1978, Sep 24, 2005.
Tags:
  1. Phill1978
    Phill1978
    Oct 15, 2004
    2,045
    48
    +84
    i dont have any spare cash to buy a new GFX card, nor do i have the facility to run DVI-D i have a laptop when i get my screen i want to plug it in straight away and run a perfect res. my laptop does the 1024 x 768 so can i get one that will look perfect plugging the VGA cable in first time.
    also i have upto £1200 max. i saw a XD HD LG running a sample HD-DEF video the 32" model was stunning. is the LG any good ? it seem like my price range and it have a black surround but does it have a fan or adjustable backlight.
  2. freekb
    freekb
    With powerstrip you can 'convince' your laptop probably to give you a better resolution.
    I plugged a laptop into an LG 32LP1D using VGA and it worked spot on first time.
    If you send it 1360x768, it does 1:1, otherwise it scales. That was over DVI, VGA might be different.
    Fan: no fans, no noise.
    Adjustable backlight: no - maybe via service menu. The 32LX2R has auto-backlight I believe. The 32LP1D doesn't.
  3. Phill1978
    Phill1978
    Oct 15, 2004
    2,045
    48
    +84
    ahh.. ok so basically i want the LP1D thing is more expensive about £350-400 more eek, dunno if id notice the colour but if im paying on finance over 4 yrs i dont want it to be a thing that annoys me.
  4. freekb
    freekb
    The LP1D has freeview, while the LX2R doesn't.
    The jury is still trying to work out if the panels are the same or different on the two models.
