32" Widescreen TV advice needed.
Discussion in 'TVs' started by Glenn Keen, Mar 26, 2003.
  1. Glenn Keen
    Glenn Keen
    A friend of mine is looking to by a 32inch Widescreen TV with a budget of £500-£900.
    He has looked a round a few stores and quite liked a couple of the Thompson TV's.
    His questions are:-
    1. Are the Thompson Tv's any good?, we've never met anyone who's owned any Thompson TV's.
    2. Is the extra cost of a 100htz TV worth it over a 50htz one?
    Any advice or suggestions would be greatly welcome.
    He likes the Sony, Philips & Toshiba TV's a lot but is wondering what to get & wether they are worth the extra cost over something like a Thompson TV.
    Thanks for any help/advice
    Glenn.
  2. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    Don't know anything about Thomson but I own a Sony 32' fx66 and it is great you can pick them up for around the nine hundred mark.........as for 100hz once you watch one on a regular basis you will not go back to 50hz the difference is amazing.
    Hope this helps a bit ...try searching on this forum as there is tons of info on all types of set:smashin:
