32" Under £300
Discussion in 'What Is The Best TV For You?' started by The Watcher, Nov 28, 2010.
  1. The Watcher
    The Watcher
    Jan 18, 2005
    64
    Title says it all! Really confused by the amount of choice out there.
    Looking for good picture/sound. At least two scarts, as not planning Sky HD just yet.
    Not sure about buying a refurb, electrical-deals items - Get great deals on Portable Audio MP3, LCD Plasma TV items on eBay.co.uk Shops! seem to be reliable based on feedback & google.
    RS an option, though I'd have to travel 40 miles on public transport to do it.
    Any/all advice gratefully accepted
    Thanks,
    Watcher
  2. The Watcher
    The Watcher
    Jan 18, 2005
    64
  3. stevem999
    stevem999
    Oct 23, 2003
    154
    Merseyside
    +4
  4. The Watcher
    The Watcher
    Jan 18, 2005
    64
  5. stevem999
    stevem999
    Oct 23, 2003
    154
    Merseyside
    +4
    Scart switch/splitter for a fiver? Potentially sacrificing a much better viewing experience for some legacy connections that can be split/switched?
    What will you be using the 2 scart's for?
  6. The Watcher
    The Watcher
    Jan 18, 2005
    64
    1 scart for sky+ and one for home cinema. I have a scart splitter in the bedroom (LG 19" flatscreen & dvd player). It doesn't work at all well, in fact the dvd constantly interfered with the the tv, so I've now disconnected the dvd unless I need it.
    I read somewhere (maybe here) a while ago that scart splitters are notoriously inefficient, so I don't want one attached to my living room tv.
    Watcher
  7. stevem999
    stevem999
    Oct 23, 2003
    154
    Merseyside
    +4
    Guess like all things there are good and bad ones. Would your home cinema not connect by any other methods?
  8. The Watcher
    The Watcher
    Jan 18, 2005
    64
  9. The Watcher
    The Watcher
    Jan 18, 2005
    64
    I even went as far as changing the scart from dvd to splitter, but it made no difference. I've got a feeling I may have changed the splitter too.
    http://www.avforums.com/forums/crt-tvs/911446-scart-splitters-worth.html is the thread i was thinking of
  10. The Watcher
    The Watcher
    Jan 18, 2005
    64
