32" - Samsung or Toshiba?
Discussion in 'Samsung TVs Forum' started by magper, Jun 9, 2005.
Tags:
  1. magper
    magper
    Jun 9, 2005
    9
    I need a 32" LCD and I need it now! Should I go for Samsung LE32R41/51 or Toshiba 32WL56? I´m not able to see them in any store where I live so I need your help.
    My main watching is satellite broadcasting.
    Have no need for component input (at least not now).
    Which one shuld I choose?
    Which one has the nicest bezel/frame?
    Thanks for any help!
  2. ener1
    ener1
    Aug 9, 2004
    1,377
    48
    +46
    I was going to order the Samsung but none are available. I believe the Toshiba is also in short supply but i managed to get one today and should be with me tomorrow!.
    I think both look very nice and i think there is (probably) very little difference between the 2.
    Ener1
  3. msg
    msg
    May 20, 2005
    455
    Darlington
    +7
    Most apparent spec difference
    Samsung 1366 x 768 pixels
    Toshiba 1280 x 720 pixels
    (10% fewer pixels = 10% coarser resolution)
  4. magper
    magper
    Jun 9, 2005
    9
    Actually I think the Toshiba has the same resolution as the Samsung, at least according to http://www.toshiba.de/consumer/specs/271/ .
    Would prefer the lower resolution as it would not need scaling for 720P.
    Ener1: Good luck with your new LCD! Please post your opinion of it after playing around for a while.
    Can get hold of both Samsung and Toshiba at about the same price. Just can't decide. . .
  5. sprint blue
    sprint blue
    May 20, 2005
    100
    I got the Tosh in question a fortnight ago.
    The picture quality is excellent and I am very happy with it. :thumbsup:
