32" Purchase - Samsung or LG?
Discussion in 'Samsung TVs Forum' started by firstwave, Oct 22, 2005.
Tags:
  1. firstwave
    firstwave
    Narrowed down my search to 2 possible models:
    Samsung LE26R41BDX
    LG 32LX2R
    Usage:
    HTPC Via DVI or VGA
    DVD Via HTPC or component (probably via HDTV)
    Sky via scart
    Xbox via Scart/component
    Xbox 360 via component or whatever is possible.
    Based on this, can anyone recommend the best screen for me to go for. I also plan to wall mount eventually.
    My concern is that the samsung does not have DVI, but I have also read here that the VGA is excellent? is this the case?
    Did anyone ever confirm the latency, is it 8, 12, or 25ms on the samsung?
    I know both only have single component inputs, but my amp can take two inputs and one output, so that should not be a problem (been ok with my ae500 projector)
    Thanks for any input
    Darren
  2. Raze
    Raze
    Dec 21, 2003
    875
    UK
    +13
    The Sammy is 12ms :)
    I am a big fan of the Samsung, check out my thread here for a video of it in HD action on xbox360
    I tested it against a toshiba with my Componant DVD player using HQ leads I loved the Sammy and have one on order - hope to get it next week!
