32 incher for £1500-ish
Discussion in 'General TV Discussions Forum' started by t-force, Apr 17, 2003.
  1. t-force
    t-force
    May 2, 2001
    1,850
    Southampton, UK
    +137
    Hi guys,
    My Sony 32FX60 is officially written off, so I'm looking to replace it. What I'm after is another 32 incher, with at least 3 scarts, and kick-ass picture quality. I've been looking at the Sony 32FQ80, but I'm certainly not tied to Sony. Does anyone have any suitable candidates?
  2. Mick da Miller
    Mick da Miller
    Try the loewe Aventos (around £900), Vitros (around £1200) or Aconda (around £1500). John lewis will price match www.tvandvideodirect.com but you can also buy from them direct as I did as they are decent retailers. Good luck!
  3. evans
    evans
    Nov 24, 2002
    1,161
    48
    +36
    have a look at the jvc with the dist technology it will blow you away for dvd pic quality and has all connections 3 scart and is ntsc and pal progressive compatible has pap pip good menus,
    really worth a look. If you can match it up to a progressive scan dvd player like I have you are laughing also the sound from the tv speakers is fantastic really good dolby digitital.
    hope this helps
    If your a sony fan then the fq80 has good pic quality as well not as good as this one but also the price will be more too.
  4. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Definately audiotion the Loewe range but also take a look at that JVC as it sounds very good.
  5. t-force
    t-force
    May 2, 2001
    1,850
    Southampton, UK
    +137
    This month's HCC has a couple of paragraphs about the new Panasonic TX-32PD30, which has got a DRC/Pixel-plus/DIST rivalling feature, and has 4 scarts, and NTSC prog scan via component. If that could be hacked to do Pal Prog I'd buy it in a second.
    No details on Panasonic's web site though yet. Anyone with industry contacts seen this baby in action?
  6. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
